S4 Biturbo gearbox on S2 ABY Coupé...?
  • NEO
    • Oct 2003
    • 326
    Heard that the S4 Biturbo gearbox is bolt on on an S2 ABY... Is that true? Perfect fit without any hussle? I do know that there is a seperate oil cooler for the S4 biturbo gearbox but that can't be a bad thing?
    The reason for the change is a broken original gearbox. So I do need to change it and a S4 biturbo gearbox just turned up on the sales market.
    All feedback in this matter are welcome! =)
    /NEO - I have a sexual thing for big brakes.
    www.irry.com | Irry got a face lift!
    #nordicaudi @ irc.nordicaudi.com
  • ~Delta
    • Apr 2005
    • 797
    Direct replacement - I used the S4 (DSY) 6 speed tranny in my S2 - engined type 85 with no problems. The oil cooler can be a Mocal 13 row unit mounted in the front bumper (near side behind the lower grilles.
    Never show a fool a half built house.
    Never underestimate the power of stupid people in large groups.
    Life is like a **** sandwich
    The more bread you have, the less **** you eat
    • Billman
      • 4129
      is it a dirct replacement also in the Avant?
      Go Holset or Go RS4
      • NEO
        • Oct 2003
        • 326
        Thanks Delta. So you ran into no problems what so ever? How is the S4 BiT gearbox compared to the RS2 one? I mean in strength, does it handle more or less power? Or are they equals? One would think that a couple of years of evolution would make the S4 gearbox a bit stronger. Or are the interior of the two gearboxes identical? Wide first gear and so...
        • ~Delta
          • Apr 2005
          • 797
          Yep. Bolt and drive.
          • ~Delta
            • Apr 2005
            • 797
            I think the internals are beefed up on the DSY unit (looked on FA, internal shaft has different part number). The addition of an oil cooler can only be a good thing.
            • NEO
              • Oct 2003
              • 326
              Sweet dude! How much torque does the BiT come with original? How much power have you ran this gearbox at?
              • caterpillar
                • 2480
                if the car have 5 syl,ALL gearboxes will fit on the engine,details will be changed like the gearshift unit,clutch and flywheel and so on,but it will fit in.after 1992 the cars have same boltpattern to the blocks....remember the correct gearcoding in FRONT and rear!!!!!
                • NEO
                  • Oct 2003
                  • 326
                  Have done some searching. Are there two different S4 BiT gearboxes? DSY and EDU? I also read this at a forum:
                  Only a few cars used the hardened 1st.
                  The DSY has a 105J which is wide and not hardened.
                  Look at ver 6 of ETKA and look at 99 S4.
                  Couse i guess one would want the wide and hard one. But in what gearbox is that? Seems like the RS4 one is different then the S4 one? Wouldnt be good to my ABY?
                  Also found this:
                  Wich indicates that it might not be a straight fit. But if delta have mounted one and says its bolt on I guess that it should be considered as reliable information. =) So seems like maybe santa has to bring me an S4 gearbox for x-mas.
                  • NEO
                    • Oct 2003
                    • 326
                    This is also an interesting read: http://elektro.cmhnet.org/~audi/01e/DSY/
                    INdicates that some work has to be done. =/
                    • ~Delta
                      • Apr 2005
                      • 797
                      Biturbo S4 comes with 295 ft / lbs.
                      My last power output was 426 PS / 411 ft / lbs.
                      • meep
                        • May 2005
                        • 203
                        Hmmm how about 3b engines then? Direct fit more or less? What would need to be changed?
                        • NEO
                          • Oct 2003
                          • 326
                          DElta, Do you have any comments on those links i posted? Where some ppl report problems fiting the S4 BiT gearbox. SOme bolt that dosn´t line up and some other problems.
                          Another thing I was thinking about was the proctoten-system. The S4 gearbox doesn't have that little guide for the proctoten cables, right? Would I jeopardise the safty alot when removing the proctoten-system? I mean if it's connected to something vital in some way...?
